Spark Plugs
Old Dec 15, 2001 | 12:50 PM
ally69's Avatar
Spark Plugs
I am thinking about changing to the denso plugs after xmas. And am liking to do it myself I am mildly machinical mostly on old 71 chevy tho. Is it really hard or just mostly time consuming? Also if I get some in and run out of time is it bad to drive it with a mix of plugs for a short time (couple of weeks)? Also to the come pre gaped?
Old Dec 15, 2001 | 01:29 PM
Redneck Ferrari's Avatar
It's really not that hard. I've done it 3 times, it has never taken longer than 1hr 45min (1st time), to 1hr 15min (3rd time). Gap anywhere between .040-.044 depending on who tells you. There is no need to run a 'mix', it's just not that hard.
Go to Chucks page and he has a very informative how-to. I would add a telescoping magnet to the tool list. It is a must have for the 7mm coil pack bolts. Torque is 15 ft lb I believe, do a search. I've worked mainly on aluminum heads so it was pretty natural to me.
http://home.midsouth.rr.com/lightningpage
Old Dec 15, 2001 | 01:38 PM
ally69's Avatar
Also I have heard of guys blowing pugs out how tight with these aluminum heads should one tighten the plugs? Hand tight then a quarter turn is what I have used on all other trucks?
Old Dec 15, 2001 | 03:13 PM
DAVER716's Avatar
I'm in the process of changing mine right now.Took 2hrs just to take the old ones out last nite.{with the proper tools & advice from Chuck's page}Redneck where do you live?I'll fly you in to finish this for me!!J/K.I had 2 electrodes completely burned off and a 3rd with a hole about half way thru the electrode.Puttin in NGK TR's,What do I gap at?Anybody Know?THX!-Daver.
Old Dec 15, 2001 | 04:21 PM
Masterloggie's Avatar
I gapped my TR-6s at 40. I think 40 to 44 is the range.
Old Dec 15, 2001 | 07:06 PM
ally69's Avatar
What about how tight to put them in finger tight little more than finger? thanks
Old Dec 15, 2001 | 07:55 PM
LIGHTNINROD's Avatar
Daver:
How many miles did you have on the stock plugs? I've got 17,000+ and am getting worried . I did pull no. 1 plug today and it looked ok--kinda 'rusty' looking electrode?
Dan
Old Dec 15, 2001 | 08:10 PM
noelvm's Avatar
I don't know why everybody is short gapping these plugs. A bigger gap gives better fuel burn and better gas mileage. I gap mine at .44 and I run a bigger lower pulley. Mine runs great. If coil on plug can't fire over a .44 gap you must have a bad coil. In theroy, you want the largest gap that the plug will fire under all conditions, including max boost. I'm putting a 4 lb pulley on Monday and will see if the .44 is a problem with the increased boost.
noelvm
Old Dec 15, 2001 | 08:48 PM
DAVER716's Avatar
My problem was the result of running a 4LB Pulley/Hot chip/Race Gas/Ram Air set-up at the track w/stock plugs.I ordered the NGK TR5's with my mods,but did not get them in time to go to the track,so I made a few runs on the stock plugs.The stockers were fine for my 2LB pulley 4-way chip,but the new mods were too much!Also had some coolant & oil leaking down onto my starter and O2 sensor cat area.And a slight Knock.Drove home 55 miles @ 70MPH with no more problems.Nothing on the garage floor next A.M.All fluid levels are o.k. w/no contamination.I'm hoping changing these plugs is the end of my problems,but i'm a little worried.
Old Dec 15, 2001 | 10:03 PM
I fly for free anyway! QUICK TIP - A couple of beers, NOT a six-pack
Old Dec 15, 2001 | 10:10 PM
2001 SVT-F150's Avatar
Plugs no problem...
I changed mine to Densos last week, took 1 hour & 20 minutes. Very straight forward. The only tricky part for me was the 3rd plug back on the drivers side, the 7mm coil screw is tough to get to.
