4x4 Trans pan
Old Dec 15, 2001 | 03:35 AM
zbornac's Avatar
4x4 Trans pan
I was looking on fordpartsonline for:
Trans Pan - F81Z 7A194 BA
Filter - YC3Z 7A098 BA
Gasket - ?
but when I enter the part number I get a bunch of choices. Are any of these different, or are all of them the same, just with different desciptions? The prices are all the same, but all of this just confuses me. Any help would be greatly appreciated. Also, if anyone has the part # for the gasket that would be greatly appreciated as well. Thanks.
Old Dec 15, 2001 | 04:30 AM
J15BIG's Avatar
go here
http://www.lightningforceperformance...transpans.html
the gasket is reusable, you dont need a new one. im pretty sure the stock gasket will work with the new pan.
hope this helps
joe
Old Dec 17, 2001 | 09:06 PM
soap's Avatar
Unhappy Different numbers
I just got my new 4x4 pan and filter and went to look in the owners manual for refill capacities (I know the 4x4 pan holds more) and it says 15.9 quarts. I did a search on here and it seems people are saying to add 8 quarts after swapping pans. Why are these capacities so different.
--Joe
Old Dec 18, 2001 | 07:22 AM
curmudgen's Avatar
Maybe the torque converter holds 7.9 quarts ?
Old Dec 18, 2001 | 09:42 PM
soap's Avatar
Question
Does anyone know.........maybe Gregg (Factory Tech) will see this
---Joe
Old Dec 18, 2001 | 10:32 PM
RedThunder's Avatar
When I did my trucks service w/ 4x pan and draining converter it took 15 quarts.
The old gasket will work all E4OD/4R100 pans are the same, bolt pattern wise.
I used the early 99 superduty pan, the drain plug faces rearward, rather than down. I got it for free, so I can't complain.
Old Dec 19, 2001 | 07:07 AM
Factory_Tech's Avatar
Dropping the an and adding an deep plugged pan works out to needing about 7-8 quarts, the rest is in the converter and in the clutches, wormtrail etc....The factroy deep pan holds 24 oz more than the stock pan.
G
Old Dec 19, 2001 | 08:32 AM
soap's Avatar
Wink Transmissionus Maximus
Your tranny knowledge never ceases to amaze me
Thanks again Gregg
---Joe
