Boost Dump unplugged..Check eng light on?
Old Dec 15, 2001 | 01:31 AM
nitrous63's Avatar
Question Boost Dump unplugged..Check eng light on?
Well I unplugged the boost dump(worked well saw a difference)now the check engine comes on .Anyway to shut it off with out plugging back in?Thanks
Old Dec 15, 2001 | 01:36 AM
Lightning Boy's Avatar
The wire connector or the pink vacume line?
Old Dec 15, 2001 | 01:39 AM
nitrous63's Avatar
The wire connector..
Old Dec 15, 2001 | 01:52 AM
I have no clue why it is on... It shouldn't be... Clear the PCM and see if it comes back on. If it comes back on find out which code(s) is popping up.
Old Dec 15, 2001 | 01:59 AM
nitrous63's Avatar
Please forgive my ignorance But how do I clear it?And thanks for the help
Old Dec 15, 2001 | 02:03 AM
nitrous63's Avatar
Is it possible I unplugged the wrong one..However I dont see how..But it is the plug closest to the pink vaccum line??
Old Dec 15, 2001 | 07:03 AM
Don's Bolt's Avatar
Have you been racing lately or doing any big burnouts. It sounds like you might have slightly over reved it and set off a code.
Plug it back in disconect the battery for a while and see what happens.
Old Dec 15, 2001 | 09:25 AM
Are you sure you unpluged this connector?
Old Dec 15, 2001 | 12:48 PM
alphadoggy's Avatar
Red face
Same thing happened to me when I unplugged the solenoid at Irwindale. Had to disconnect the battery (I hate to do that, lose all the radio pre-sets) but the light went away.
Old Dec 15, 2001 | 05:26 PM
LOCOSVT's Avatar
My CEL came on as soon as I disconnected mine. It was just idling in the driveway, I didn't even get to drive it before it came on. Just reconnect, then disconnect the battery for a few minutes to clear the CEL.
Old Dec 15, 2001 | 06:37 PM
99SVT's Avatar
Your CEL should not come on by disconnecting the boost dump plug. Mine has been disconnected for over a year now, without any light at all.
Either you have disconnected the wrong thing, or something else must be wrong.
FYI, disconnecting the battery does not lose the presets, just everything else on the radio. At least on mine it doesn't.
Jer
