Boost Bypasss=More HP????
Old Dec 14, 2001 | 07:04 PM
J15BIG's Avatar
Everyones been talking about getting rid of the boost bypass. I was just reading on the Magnuson website that the boost bypass in a way gives you HP. When your cruising at like 60 and your in vaccum(sp?), if your bypass is closed, you loose hp, i think. i know that it doesnt really matter when your cruising, cuz when you floor it your goin to be in boost. but it thought i would post this ne way.
here just go to this page and read it
http://www.magnusonproducts.com/bypass_valve.htm
later
joe
Old Dec 14, 2001 | 07:53 PM
Lightning Boy's Avatar
We were talking about Boost Dump not Boost bypass. These trucks come with a wastegate (Bypass) from the factory attached to either the Eaton or the intake (Not sure, would have to look but dont have a truck to look on).
When running around town the wastegate is open most of the time dumping excess boost that is not need and would case extra heat. When you hit WOT, the vacume is gone and the wastegate is closed allowing possitive boost.
Is that clear enough or do I have to write a book?
Tommy
Old Dec 14, 2001 | 08:16 PM
LOCOSVT's Avatar
You're both talking about the same thing...the point is that if you disconnect the boost bypass, you don't allow the blower to freewheel in vacuum conditions(wasting HP as heat). Think of the bypass as a way of equalizing the pressure before and after the blower. If the bypass is disabled, the blower is always going to have pumping losses due to the differences in pressure. If you have 14 lbs vacuum before the blower, you may have only 12 at the manifold.
Also, when you close the throttle, the air supply to the blower is suddenly cut off. The bypass valve allows a smoother transition to vacuum and back to boost when you open the throttle again.
BTW, I've got mine disconnected...my engine warms up quick in this cool weather.
Old Dec 14, 2001 | 09:09 PM
JeffsLightning's Avatar
Oh boy here we go again. The boost dump is when the PCM sees excessive rpm's or one of many many engine/tranny problems then it is activated. This is why people disconnect the electrical plug at the track(some on the street). With it unplugged you will NOT dump boost. Some people choose to buy the kit(don't know why) for this function. The boost bypass is vacuum operated and different from the boost dump. They both use the SAME butterfly that is in the bottom/back of the blower. The boost bypass is solely dependent on engine vacuum or the lack of it to operate. Do I need to write a book.....heheheheh thats for you LB....LOL
Old Dec 14, 2001 | 09:17 PM
whitetoast11's Avatar
ok,, so our trucks have both a boost dump and a boost bypass in them. Boost dump is what we unplug to stop our trucks from mistakingly dumping extra boost when we need it. Boost bypass is used to control boost pressure and engine heat so that our boost is used to its maximum capabilities.
I hope thats right cause thats the only thing that makes cents to me
Old Dec 14, 2001 | 09:20 PM
whitetoast you GOT IT!
Old Dec 14, 2001 | 10:20 PM
I was trying to be vaige (sp?) so he would think. But thanks Jeff for writeing the summary of the book .
Old Dec 14, 2001 | 10:29 PM
hey if there was a book i'd buy it and read it, got to learn somewhere you know
Old Dec 14, 2001 | 10:34 PM
Hummm.... Maybe I could become an author. Make some money.... Nah ill just stick with being an engineer.
Old Dec 14, 2001 | 10:50 PM
did you say engineer??? I just got my degree last year as an ME from University of Michigan. I dont work in the field though for now, happy with my other job right now, but maybe soon will be working at US Army Tank Com
Old Dec 14, 2001 | 10:57 PM
J15BIG's Avatar
my bad, i thought they were the same. so if you unplug the boost dump(which is what everyone is doing?), you will still have the boost bypass? right?
thanks
joe
Old Dec 14, 2001 | 10:59 PM
thanks
joe
Correct.
Yeah im looking to be a ME as well, hopeing to go to UT or A&M.
Old Dec 14, 2001 | 11:09 PM
Lightning Boy
Good luck with wherever you go, i had lots of fun my last year there, even though i'd hate to go through it again
