Traction in Seattle
Old Dec 13, 2001 | 07:13 PM
Coldie's Avatar
Traction in Seattle
So in case you didn't know, we get a bit of rain here in Seattle (14" this month).
Does anyone have idea suggestions for decreasing wheel spin in wet weather?
The wheels don't hop, they just spin... In fact I can do a 5-10 second "burnout" and then check the tires and they are barely warm.
Coldie
Old Dec 13, 2001 | 07:30 PM
Silver-Bolt's Avatar
Just a little south of you here. It takes a little finesse to keep them point the right direction. My Snug-Lid weighs about 100-120 lbs and that helps quite a bit. A little weight in the back would do some good.
Old Dec 13, 2001 | 08:09 PM
Probleminfected's Avatar
Old Dec 13, 2001 | 09:00 PM
Jay Lincoln's Avatar
probleminfected, the Truck-Traks don't seem to help much in the wet, unless you can get some weight over the rear wheels. I have a heavy *******'sbed cover that weighs in around 100 lbs. If you can get the truck to hook, a bump will upset the traction and you will spin the tires.
In the dry, however, the traction bars will help a lot. They provide weight transfer to the rear which improves traction.
I drive with mine daily, and have logged about 30,000 miles with them on the truck. I really notice their absence when I take them off for any reason.
Old Dec 13, 2001 | 10:18 PM
alphadoggy's Avatar
Lightbulb
Sandbags
Old Dec 13, 2001 | 11:20 PM
Coldie's Avatar
expensive sandbags
I've got really expensive sandbags. They're called SCUBA tanks
How much does everyone drive around with?
Old Dec 13, 2001 | 11:26 PM
Coldie's Avatar
errr....
That's how much weight does everyone drive around with?
Old Dec 14, 2001 | 01:02 AM
SLVRLTNG's Avatar
I just have my snugtop hard tonneau cover. Just gotta stay outta the throttle a little more!! These people around here don't know how to drive in the rain, figure that one out!!!..JR
Old Dec 14, 2001 | 09:50 AM
Go to Home Depot and pick up a 2" X 10" X 6' plank, 2 50 pound bags of sand, and a couple of heavy duty trash bags.
Cut the board to fit across the bed. Near the tailgate there is a slot on each side that the board will slide into. This will keep the bags from moving around. Put the sand bags in the trash bags and drop them in the between the tailgate and plank. 100 pounds will make a difference.
Old Dec 14, 2001 | 03:24 PM
Bad as L's Avatar
Talking
I don't know what you guys are complaining about, I'm sitting in Redmond right now and the weather is perfect. And I'm sure it will stay like this for at least 10 more minutes
Dale
Old Dec 14, 2001 | 04:12 PM
alphadoggy's Avatar
Redmond, eh? You don't work for the Evil Empire, do you Dale?
Old Dec 14, 2001 | 06:07 PM
Coldie's Avatar
Evil Empire
I work AT the empire. Anyone else on campus? Maybe we can get a MS lightning club together.
Hadden
Old Dec 14, 2001 | 06:45 PM
Bad as L's Avatar
Nope dont work there, I work just down the street. I work for a small tool and die company that has done a lot of work for MS in the past though.
Dale
