Valve Body and Line Mod Valve
Old Dec 5, 2001 | 03:55 AM
J15BIG's Avatar
I ordered the PSP valve body and I am very happy with it. But I want harder shifts than what i got with the valve body. Can I still use a line mod valve?? If i can still use one, will it make difference since I already have that new Valve body?
thanks
joe
Old Dec 5, 2001 | 07:20 AM
Lightning Boy's Avatar
Ask your tuner, whom ever it may be, to raise the line pressure in your chip the next time you send it back for a re-burn.
Old Dec 5, 2001 | 03:15 PM
J15BIG's Avatar
i dont have a chip yet
joe
Old Dec 5, 2001 | 03:20 PM
LightningTuner's Avatar
Joe, a line mod valve is just one part of a complete shift kit. Your Factory Tech valve body has the upgraded line mod valve already in it. I can give you more line pressure with a chip, that won't be excessive or damaging, but will give you a harder shift than what you currently have. Hope this helps.
Old Dec 5, 2001 | 03:29 PM
J15BIG's Avatar
thanks sal, when i order a chip i will have you do that for me.
Old Dec 5, 2001 | 07:48 PM
soap's Avatar
Question Attn: Sal
Hey Sal....Is a Level 10 and a FT valve body too much. I know the parts (springs) come in the Level 10 shift kit to serve the same purpose as the valve body, but I like the idea of replacing the entire valve body not just a few springs in it.
I am referring to stock pressures, not getting it incresed by a chip.
Thanks, Joe
Old Dec 5, 2001 | 07:54 PM
Joe, I'm not quite sure I understand what you are asking. Do you want to combine the two? The FT Valve Body has the same parts in it as a Level 10 shift kit, just installed and matched to a new body casing.
Old Dec 5, 2001 | 08:10 PM
soap's Avatar
OK maybe I am the confused one here (actually I am sure it is me ).
Maybe I should say this.....what exactly is all included in a Level 10 kit. Because I have read from the forums that a Level 10 kit shifts much harder that a FT valve body. Isnt there alot more to a shift kit than just the springs to increase line pressure?
Sorry if this is even more confusing.
Joe
Old Dec 6, 2001 | 09:17 AM
Factory_Tech's Avatar
A Level 10 kit has 3 springs and a line mod valve, you install it in your existing accumulator. A PSP/FT sshift kit is a new accumulator with the three springs and a line mod valve installed and with upgraded 310 springs and 321 valves (the ones deeper in the valve body). The line mod valve in the Level 10 is a larger size than the one is the PSP/FT kit nad the boost sleeve in the Level 10 is aluminum, the one in the PSP/FT kit is stainless.
They do about the same thing.
G
Old Dec 6, 2001 | 12:47 PM
soap's Avatar
Wink I 'preciate it
Thanks Factory_Tech
