Lowering the rear only
Old Dec 2, 2001 | 06:04 PM
SVTRULZ's Avatar
Hi there I'M new to this but here goes.
I don't want to loose the ride I have now,And I don't want to
put in the C-sections.How do the L's look with just the rear droped? I will still run the 18's.How far can you drop the L at both ends without loosing the ride? Thanks for any help
Old Dec 2, 2001 | 06:23 PM
ICULOKN's Avatar
Get you a 2in rear shakle drop. It levels the truck out some and helps with hook up on the stock tires.....
Old Dec 2, 2001 | 06:26 PM
captainoblivious's Avatar
or rear springs, Hotchkis has a stiffer rear spring that lowers the rear, but changes the ride quality. Or the new composite springs
https://www.f150online.com/forums/sh...hlight=springs
Old Dec 2, 2001 | 06:28 PM
ASVTFordBoy's Avatar
Check with Mark. He has about the best price on 2" drop shackles for the rear.
Lightning Force Performance
Old Dec 2, 2001 | 07:38 PM
L8 APEX's Avatar
Stock suspension is the best for ride and clearance. I dropped mine with the Hotchkis kit 1/2. Stock the rear bump stops have 4" to the axle "travel", with it lowered 2" it takes clearance/travel. So now the rear bottoms about once a day or so. As soon as I put over 400lbs in the bed it is on the bump stops. 2" on the rear makes it a smidgen lower than the front.
Old Dec 2, 2001 | 08:04 PM
L8 APEX - I haven't bottomed out once yet with Hotchkis springs
Old Dec 2, 2001 | 08:32 PM
L8 APEX's Avatar
I guess the combo of rough streets and high speeds are a main factor in my bottoming out. Or maybe it is the 1000 lbs of concrete and play sand in the bed
Old Dec 2, 2001 | 08:50 PM
Madhouse's Avatar
Old Dec 2, 2001 | 09:56 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Apex,
Ever think about cutting a 2 x 10 to fit in the 'guides' on either side of the fenderwells?
I'd hate to see (or feel) what 1000 lbs of sand and concrete does to the front of the bed (and cab) under sudden "OH *****!!!" braking...
Cool bedliner by the way.
Bob
Old Dec 2, 2001 | 10:05 PM
L8 APEX's Avatar
Thanks Bob! That liner is NO slip stuff I couldn't drag the bags off I was on my way home from getting my liner put in and ran into a buddy that would feed me if I helped him pour a walkway. I drove regular and got no cargo shift at all. We have a group deal with a local XLiner guy he gave us the SVT logo free it makes them look factory I would like it tinted two swquirts lighter to match the side rails better
Old Dec 3, 2001 | 06:35 PM
ICULOKN's Avatar
I never bottmed out with the 2in shakle drop. It makes the truck sit close to level, still alittle higher than the front, but very close to level!!!!
Old Dec 3, 2001 | 07:28 PM
97Tbird4pt6L's Avatar
Has anybody had any warranty problems with just the rear dropped? I really can't imagine any problems.
I would really like to see my father lower his truck with a set, so I am very interested in what you guys recogmend. Is one brand preferred over another?
Old Dec 3, 2001 | 07:31 PM
ICULOKN's Avatar
Bell Tech or Ground Force, both are the same & about the same price.....
Old Dec 3, 2001 | 07:39 PM
2" Lowering Shackles
This was probably one of my best mods. It almost leveled my truck out, but it's still just a little higher in the back.
If Interested
Old Dec 3, 2001 | 08:34 PM
Ok, so how much should I pay for a set and where should I get them from?
EDIT: OK, just saw your link.
