Fuel Pressure Guage
Old Dec 2, 2001 | 05:11 PM
ally69's Avatar
Fuel Pressure Guage
Those of you that unsrewed you shareder(spelling) valve and screwed in your sending unit to the fuel rail Which part number autometer did you use. Also what adapter exactly did you use?
Old Dec 2, 2001 | 06:29 PM
soap's Avatar
Exclamation Part number
Auto Meter part number 3280 is the NPT adaptor to fit the sender into the fuel rail.
Hope that helps......Joe
Old Dec 2, 2001 | 06:44 PM
ally69's Avatar
Thanks for that part number my typing is very bad what part number guage are you using?
Old Dec 2, 2001 | 06:50 PM
soap's Avatar
Exclamation Part Numbers
Auto Meter Phantom #5709 is the gauge.
Auto Meter #3280 is the adaptor.
Joe
Old Dec 3, 2001 | 11:14 AM
loosebolt's Avatar
Fuel pressure gauge and A/F ratio
Does the fuel pressure gauge help determine A/F ratio?
If so, how does that work??
Old Dec 3, 2001 | 11:30 AM
MXRacer's Avatar
Alright, now I'm confused...
soap: Is the correct part number for the adaptor 3280 (what you said initially), or 3208 (which you later replied)...or are they two separate parts and infact we need both?
I have a three gauge pod myself- also with the 2-1/16" Autometer Phantom series Boost and A/F ("light show") gauges that you have, but the bottom spot is still empty because the water temp gauge I wanted to hook up to my IC Res seems to be such a pain to install I don't even want to bother right now. I had been thinking of trying the F/P gauge myself, and with the part #'s you just made my decision that much easier.
Thanks. Later...
GK
Old Dec 3, 2001 | 11:48 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
hmmmm, wonder what gauge Beefcake bought?
ally,
Is this a true electric gauge or is there liquid inside?
thanks,
Bob
Old Dec 3, 2001 | 12:08 PM
beefcake's Avatar
more info please,
me and bob will be doing my f/p this weekend, i didn't know an adapter is needed for the rail, i have the guage, but not an adapter
what all will i need?
Old Dec 3, 2001 | 01:15 PM
soap's Avatar
Sorry for the confusion....I type like a retard sometimes
The adaptor part number is #3280 here is the link
http://www.autometer.com/hp/index.html
The gauge number is the same #5709
Joe
Old Dec 3, 2001 | 01:18 PM
soap's Avatar
Exclamation More Help!!!!!!
Beef....
If you bought the #5709 electric fuel preesure gauge then you need the #3280 NPT adaptor. It is a 1/8" to 1/16" reducer to fit the pressure sender into the rail where the shrader (sp?) valve was at.
Joe
