lower pulley sizes
Old Dec 2, 2001 | 04:33 AM
krzcwby's Avatar
Question lower pulley sizes
I have a 2000 L. How much bigger can I expect a new pulley to be over stock, if it increases boost 2lbs or 4lbs. Do you need to get a longer belt? Or is the factory size long enough. I'm just trying to get a feel for these new pulleys and their sizes I've always been a Ford boy but new to this whole blower thing.
Old Dec 2, 2001 | 04:38 AM
L8 APEX's Avatar
I may get some measurements in the morning if no one else responds. My PSP pulley is .5" bigger than stock for 2 lbs. I also got the belt for it and it was special order from HiLo Oriley's since it is 8 rib and most are 5 or 6 rib. On memory I think stock is 7.75" and PSP is 8.25"?
Old Dec 2, 2001 | 04:53 AM
krzcwby's Avatar
How's the weather in Arlington I'm heading back to Dallas on Friday. I hope It's good I'm driving my L back it's over 2000miles from Calgary.
Old Dec 2, 2001 | 08:17 AM
LIGHTNINROD's Avatar
No, the s/c belts aren't 'special order'. You can get them from a NAPA store--made by Gates. It is 8-ribbed--the stock belt is used by some for the 2lb pulley. I chose to use a longer belt-NAPA-25-080670. For my 3lb pulley, JL sent(with the pulley) NAPA-25-080680 which is 1 1/8"x 68 5/8"s
Dan
Old Dec 2, 2001 | 10:07 AM
Fast Gator's Avatar
I've been using the stock belt with the 2 lb pulley. No problems
Old Dec 2, 2001 | 11:53 AM
L8 APEX's Avatar
The weather down here is fine with high 60's and full sun with a southern breeze I guess some parts stores are better stocked than others. Dallas is a large city and I looked at 4 chains (Napa, Pep Boys, AutoZone, HiLo) and no one had it HiLo could get it in a day from their warehouse. Same on the NGK plugs some guys get the TR's and iridiums off the shelf but I can't get them around here? My 2lb belt is a Gates K080670 green stripe lifetime. The stock belt would not fit without breaking off the stop tab on the tensioner.
Old Dec 2, 2001 | 12:03 PM
Bad as L's Avatar
Smile Pulley sizes
Stock pulley 7.40"
PSP 2lb 7.90" +.50"
PSP 4lb 8.40" +1.0"
LFP upper 2.80" -.125
I just installed the PSP 4lb with an LFP upper and run the gates K080660 belt. The belt fits nice and snug with very little slippage (and yes, I broke the tab to get it on there)
If anybody knows the diameter of the 3lb and 5lb pulley that are out there, I'm curious to know.
Dale
Old Dec 2, 2001 | 04:52 PM
DaveRed99's Avatar
it comes with it
most pully kits come with the new belt....... powersurgeperformance.net !!!!!!!!!!!!
