detonation?
Old Nov 30, 2001 | 10:23 PM
usahooters's Avatar
detonation?
Ok quick question, If I have a detonation problem will running a cooler plug help any at all, or is the only way to fix it is to retard the timing on the chip?
Old Dec 1, 2001 | 01:10 AM
ICULOKN's Avatar
Hopefully JL or Sal will see this and answer. i would think some could be cleared up by cooler plugs. I am having somewhat of the same problem, I think Mine is due to cool air. It does not so it all the time, But I am thinking about changing plugs as well...
Old Dec 1, 2001 | 07:22 PM
usahooters's Avatar
iculokn, Hey buddy I talked to a lot of friends today and hopfully got us an answer. Yes going to a cooler plug can help with a detonation problem. If your having a real small problem with it you may just need to close the gap up some. Definetly get rid of the stock Platinum plug because the hold heat bad. With a TR5 plug its usually set at .040, then go to .035, this would give you less chance for detonation. If your haveing a bigger problem than go with the TR6 and may even need to gap it down also. The Autolite103 plug is being used by alot of people because it is a very cold plug and guess what it same as a NGK TR6. Anyway if your also haveing a detonation be sure and use a good Octane booster, If the plugs and Octane booster don't fix it don't run it hard until you get the timing retarded or you will be buying a new engine.
