HELP! How to remove door panel???
Old Nov 28, 2001 | 04:24 PM
D-townSVT's Avatar
Could someone please advise me on how to remove the door panels? I'm trying to replace both door speakers. Do I just pull the panel out? Is it held by clips? Thanks.
Old Nov 28, 2001 | 04:33 PM
cteselle's Avatar
There are 2 screws that hold the door panel on. You will first need to remove the vertical plastic piece to the left of the window (driver side), and the the black plastic piece behind the handle. You will then see the 2 screws. Once those are off, the panel can be removed by pulling up and out.
Don't forget about disconnecting the 4 (i think) plugs for your power windows, locks, mirrors, and the light.
It's really easy.
Old Nov 28, 2001 | 04:34 PM
Silver_2000's Avatar
Some pictures are included in this HOw To
http://www.svtlightnings.com/svt/key...ad_install.htm
Doug
Old Nov 28, 2001 | 04:37 PM
Redneck Ferrari's Avatar
If its like other fords
After pulling out a couple screws (doorhandle, door latch) you then pull straight up toward the sky.
THATS IF ITS LIKE OTHER FORDS! I have not pulled the door panels off the L.
Old Nov 28, 2001 | 04:43 PM
CornerCarver's Avatar
Red's right, lift UP.
Old Nov 28, 2001 | 05:14 PM
Gotta love it, there's always a "how to" somewhere
