question for tuners
Old Nov 28, 2001 | 09:48 AM
ally69's Avatar
question for tuners
My Super Charger snout always rattles when the outside air temp drops below say 40. Makes no difference what the motor temp is or how long it has been running. Only does it in winter and only when air temp is below about 40.
I have hear bearings or cavatation could either of these be made worse by air temp? Also should I worry about it?
Old Nov 28, 2001 | 09:56 AM
Silver-Bolt's Avatar
Check the oil level in the blower.
Old Nov 28, 2001 | 11:39 AM
ally69's Avatar
Even after sitting all night when I start to remove the allen bolt It starts to run out does that mean it is full? Also Would that only effect it when it is cold?
Old Nov 28, 2001 | 11:46 AM
J.D. Blackwell's Avatar
Ally69
Is it at WOT? If so it might be pinging or detonation. You really need a reburn on your chip when it gets cold. That is the only downside about chips. Reburns when you add a new mod and when the weather changes.
If it does it at idle your right about the bearings. I have heard of peoples' snout bearings wear out. I personally haven't had that problem. Are you running an aftermarket blower pulley?
Old Nov 28, 2001 | 12:43 PM
ally69's Avatar
No just at idle I do not have any mods other than air box and the thing is it did it last winter and then nothing all summer at all then winter here again it starts but only when it is like under 40 next day 58 degrees and nothing?
Old Nov 28, 2001 | 01:00 PM
That's a newbie for me.
Old Nov 28, 2001 | 03:16 PM
Oil level should right to the bottom of the hole with the plug out. I doubt that is the problem. Probably just very thick oil when cold. As the oil warms up it thins out and the noise goes away.
