Ignition System on Lightning
Old Nov 21, 2001 | 11:07 AM
Frankinaustin's Avatar
Are the ignition systems on Lightnings the same on a standard 5.4L engine? I've ordered a 9PSI ATI Procharger and I'm curious if I will need to do something to my stock ignition system. I drive a 2000 F150 4x4 5.4L.
Also, those of you with higher boost levels on your L's - Have you had to beef up your ignition?
Thanks! Frank
Old Nov 21, 2001 | 07:55 PM
loosebolt's Avatar
This question is pondered quite a bit....
Rick Byrnes broke the 200 mph club at Bonneville Salt Flats in his 4 cyl. Merkur XR4TI. Through extensive testing, he was determined the stock Ford ignition system to be quite capable.
....just fyi....
Old Nov 21, 2001 | 08:32 PM
Silver-Bolt's Avatar
If your ingnition is the same as the Lightning your system should be fine. Your ignition timing may need adjustment. I would be more concerned about your fuel system. Is it up to the new task?
Old Nov 21, 2001 | 08:49 PM
Don's Bolt's Avatar
Frank
Get a hold of Mike Troyer over at the computer chip forum, he will help you out.
You may want to talk to crash over at the Superchargers & Turbochargers forum he should have some good info for you.
