Bucket seat & Center Con.
Ok for the guys that have this done. I need to get a Center Con. out of a Expedition right? is it just the center peice or do I need some of that dash?? As for the seat you take it and have it cut to the size of a bucket seat right??
You need just the console and the floor mounting brackets. None of the dash is needed. You could take the oem pass seat, frame and all, and have it hacked down to bucket seat size but you could also get the right parts and to it that way. You will need to have the oem cushion and cover cut and sewn to fit the lower frame. The inside of the cushion is straight not rounded like the outer edge. Look at the drivers seat and do it backwards on the pass side. The backrest off the oem pass seat comes off and goes onto the new lower frame. Parts and numbers are listed on my web site. Click on "my mods" in my sig. Look under "peices and parts/seat mod".
Good luck.
Good luck.
