lowering kits
Old Nov 19, 2001 | 04:30 PM
loosebolt's Avatar
I picked up the kit at my local Ford dealership and installed it myself. It took about 6 hours, including putting in the new NAPA cam bolts. Easily a 1 person job.
Old Nov 19, 2001 | 04:55 PM
LightninSVT's Avatar
How soon do you need to get an alignment done after lowering your L? I just did the FRPP kit. The guy that did it said wait a couple weeks for it to settle and then take it to an alignment shop?
It rides really great, and I think the alignment pulls less now than it did before the kit was installed. I've got the NAPA cam bolts, should I get it done really soon?
Old Nov 19, 2001 | 05:00 PM
ICULOKN's Avatar
I just got mine done as well, I gota get a alignment to...
Old Nov 19, 2001 | 06:30 PM
loosebolt's Avatar
I got mine done right away. After installing the cam bolt kits, my cast and camber were off quite a bit.
I don't think you will have many problems as far as tire wear with cast and camber out, but your handling and vibrations through the steering wheel will suffer.
Old Nov 19, 2001 | 07:55 PM
Z28KLR's Avatar
anybody drop the back another inch after installing the FRPP kit. I have the kit on my truck, wondering how it would look down 3 in the back?
Old Nov 19, 2001 | 11:28 PM
Kyle's Avatar
Here is a pic of my truck with the Ground Force kit and AIM hangers for the extra drop in the rear..
Old Nov 19, 2001 | 11:36 PM
Z28KLR's Avatar
Kyle, thanks looks good. so you just have the 2" ground force drop coils( blue ones) up front. Did you have to mess with pinion angle?
Old Nov 20, 2001 | 12:37 AM
JeffsLightning's Avatar
Kyle how much longer is the AIM shackle than the FRPP one? Can you give me a part number and some info on where to get the AIM? I too want to level out my 01. thanks Jeff
Old Nov 20, 2001 | 12:54 AM
Z28KLR's Avatar
Jeff what Kyle did is replace the stock hanger with a 2" drop hanger, then put his shackel on the 1" hole, for a total drop of 3"
