Why Doesn't This Work??
Old Nov 8, 2001 | 04:32 PM
2kL's Avatar
2kL
With the truck off, i unplugged the plug on my inner cooler pump behind the lower bumper cover. I then ran a wire from the pos. terminal on the battery to the pos. post on the pump, and then ran a wire from ground to ground on pump. I did this as a test. The pump did not come on or run. Why not. I only left wires plugged on for a second, as i didn't want to burn anything up incase this was wrong.
Why didn't it work?
Brandon
Old Nov 8, 2001 | 06:48 PM
4D THNDR's Avatar
Should have.
Old Nov 8, 2001 | 08:03 PM
LIGHTNINROD's Avatar
Check for a blown fuse?
Dan
Old Nov 9, 2001 | 01:27 AM
z96Cobra's Avatar
If you ran wires direct to the battery and the pump, the only way it shouldn't work is if you didn't have a good connection at the battery or the pump terminals. I would guess that you didn't get a good ground. To check to see if you are getting power through the wires you can stick the wires on your tongue just like you would test a 9v battery... WARNING: I'M NOT RESPONSIBLE IF YOU WET YOUR PANTS...
Later,
Roger
Old Nov 9, 2001 | 07:52 AM
2kL's Avatar
2kL
where is the fuse located for the pump?
Old Nov 9, 2001 | 08:01 AM
lightning2strikes's Avatar
test
foger lets see you do the test sunday.
Old Nov 9, 2001 | 08:02 AM
mocklab's Avatar
What fuse? The connection was direct from bat to pump, no fuse. I can't imagine why it wouldn't work either. OH wait, could be there's a fuse in the pump? Maybe the pump gets a second signal from some type of thermostat to kick on?
Old Nov 9, 2001 | 08:18 AM
tommylightning's Avatar
Supplied power to the pump by finding a source that was hot all the time (with key off). I used the positive terminal on the starter solenoid. Just disconnected the battery and removed the nut and connected the wire to that terminal. Then a hole was made in the cover that covers the starter solenoid, installed the switch. Connected the wire that I installed to the starter solenoid to one side of the switch and ran a wire to the pump. I connected it close to the pump on the colored wire (don't remember what color and can't check because truck is in shop getting a new motor.) It looks to me that they have some type of heat device (a ceramic piece connected to the pump) I connected the power in front of that so that if this was the case it would be bypased. I know my instructions are very cryptic so if you have any questions let me know.
Old Nov 9, 2001 | 09:02 AM
DL's Avatar
DL
Hey Tommylightning,
Shoot me an E-mail, I need to ask you something off line..
Thanks,
DL
Old Nov 9, 2001 | 10:34 AM
4D THNDR's Avatar
Exclamation
It had to work. The only possibility was a bad connection or you just didn't hear it running. Try putting alligator clips on your jumper wires so they grip the connections better.
