trans cooler line kinked- need help for fix
Old Nov 1, 2001 | 07:32 PM
99WhiteBeast's Avatar
Question trans cooler line kinked- need help for fix
Can't get anyone on the transmission board to respond.
Surely some of you have come across this before:
I kinked the last inch or so of cooler line when dropping my tranny. (AODE on 95GT-My work car- The L is my main ride)
Can this be spliced or repaired?
Any tips or solutions would be greatly appreciated
Old Nov 2, 2001 | 08:56 AM
Factory_Tech's Avatar
cut it and use a piece of 3/8 ID rubber fuel line with two clamps on each side, this is how you install the Ford factory external fluid filter so the line should hold the pressure.
G
