F1 Tyres 99/00 v 01
Old Oct 31, 2001 | 08:47 PM
Hilander's Avatar
F1 Tyres 99/00 v 01
Have read that the F1 tyres on the 2001 Lightnings have a softer compound and grip better.
Can anybody confirm this or has anybody noticed a worthwhile differance when they replace there old style F1 tyres for the newer type?
Also, Anybody know when the Nitto 315/40/18 are comming out?
All these mods and cold air make it way to easy so screw up the start
Old Oct 31, 2001 | 09:11 PM
Lightning Boy's Avatar
Hilander,
Yes the newer compound is better. We are on our 2nd set of the new compound tire. They are great for te first ~5,000 miles if you dont burn em up. When you order new F1's you will get the new compound.
Old Nov 30, 2001 | 11:12 AM
RA6870's Avatar
I have the nittos 305/45/18 drag radials and have no problems!!
Old Nov 30, 2001 | 11:26 AM
01Lightning's Avatar
The F1s are rated for a load of 1819 lbs. What is the rating on the Nittos? I would love to get Nittos when I wear mine out, but I am concerned about the load capacity.
Old Nov 30, 2001 | 11:30 AM
JeffsLightning's Avatar
RA6870 where did you get your Nittos at? thanks
Old Nov 30, 2001 | 12:03 PM
Quick96's Avatar
Are your Nittos the 555R and also are those on the stock wheels.
Old Nov 30, 2001 | 12:07 PM
RA6870's Avatar
nitto tires
I bought them at Discount Tire Company they were like $200.oo each and the load capacity is the same as the F1 they said that when I bought them.
They are 555R drag radials 305/45/18 on stock rims.
Old Nov 30, 2001 | 12:51 PM
Quick96's Avatar
Is the 305/45/18 the same size that comes on the truck from the Factory.
Old Nov 30, 2001 | 12:59 PM
No.... 295/45/18
Old Nov 30, 2001 | 01:09 PM
'00BlackLightning's Avatar
The 305/45-18's are 28.81" tall with a section width of 12.0" compared to the 295/45-18 which are 28.45" tall and have a section width of 11.6".
295/45-18
295mm/25.4 mm per inch = 11.61" section width
11.61" * .45 aspect ratio(height to width) = 5.22" sidewall height
diameter = (5.22" * 2) + 18" rim = 28.4" overall height
Hope this helps.
Old Nov 30, 2001 | 01:14 PM
Quick96's Avatar
Thanks for the info.
Old Nov 30, 2001 | 01:16 PM
How will that effect the accurcy of the speedo?
Old Nov 30, 2001 | 02:19 PM
RA6870's Avatar
Doesnt look like it affected mine at all used my g.p.s. to test my speed and it doesnt look off to me from what I can tell. Just help me off the line the tires lock up real good now very little tire spin!
Doesnt look that much different is size than the F1's i think its less than a 1/4 inch in height difference!
