Paging Beefcake
Old Oct 30, 2001 | 10:42 PM
BlownSVT2001's Avatar
Paging Beefcake
Just a question for you, when you had your Factory Tech Shift Kit installed, did you have to have your JL chip reburned? Did Factory Tech say anything negative about using their shift kit and have you noticed anything negative after installing the kit? Thanks.
Old Oct 30, 2001 | 11:24 PM
beefcake's Avatar
I didn't have the chip reburned, i imagine when i get a custom chip, i probably will not have pressure added
i think it should be ok though, since the other parts are in the shift kit, the fluid isn't all bleading around the sides, with the better valves and such I think it should be alright, better for factory tech to answer
