My rendition of cold air--->>>
Old Oct 27, 2001 | 09:03 PM
JeffsLightning's Avatar
The hose is from Ridgid and it's a dust venting hose used for power tools. It is 4" in diameter. Got it at Home Depot. The pickup at the end is a 6"x4" duct reducer.
Old Oct 27, 2001 | 10:14 PM
DR.D's Avatar
VENTILIATION
pic's not real clear. how did you route the hose?
how's it att'd? i like the idea. everybody wants so dam much for a ram air setup.
Old Oct 27, 2001 | 10:21 PM
Don C's Avatar
Jeff you have to logg off fotki then go back into it and copy the url. You must have just downloaded the picture, I can tell because there is a ? in the url
DR.D
It looks like he did something similar to what I did, this may give you a idea
Old Oct 27, 2001 | 10:39 PM
Silver_2000's Avatar
Jeff I edited your post
I removed a couple redundant img tags and the ? and everything after it...
Hope you dont mind
You can click edit to see what I did.
Doug
Old Oct 27, 2001 | 10:56 PM
DR.D's Avatar
Don C
WHat is the funnel? Is that for brake ducting?And a header reducer on the box?
Old Oct 27, 2001 | 11:38 PM
Thanks Doug....I edited my first post and added a few more pictures. What I like best about this setup is that it is 4" diameter. The hose is very sturdy also. It cost 25 bucks at Home Depot.
Old Oct 28, 2001 | 03:10 AM
sovich's Avatar
Looks good. Probably 1/4 the price i payed for the JL setup and probably works just as good.
Old Oct 28, 2001 | 06:44 AM
ASVTFordBoy's Avatar
Unhappy
Now if I could just figure out some way to throw together some traction bars with a few things from Home Depot.
Old Oct 28, 2001 | 08:24 AM
Here is another picture. A good about this setup is that you can pop a plastic 6" coffee can lid over the end whenever there is rain or other bad weather in a second. This way you won't suck in nasty water or debris...
Old Nov 12, 2001 | 11:40 AM
Here is another pic...
Old Nov 12, 2001 | 12:38 PM
J MAN's Avatar
Talking
Jeff
Looks good,Nice work!!!!! You a=saved yourself about $200.
J MAN
Old Nov 12, 2001 | 12:45 PM
L in Detroit's Avatar
looks a little similar....
Old Nov 12, 2001 | 01:02 PM
captainoblivious's Avatar
L in Detroit - I did almost the exact same thing as you. I ran two 2 1/2 ductings from the grill to the airbox. Right now I'm making my own scoops so it looks better. Very effect and I'm happy with it. Not expensive either.
Old Nov 12, 2001 | 03:39 PM
11secL's Avatar
Talking
I used my fog lights to run the ram air kit through. The installation is pretty easy and the way I did it I can still install the fog lights again with no problems. The shape of the bumber by the fog light makes an awsome scoop to take in the air. The top end power is amazing and performance is about 2x what I got from the JL ram air kit. If you want blue prints, email me @ lightningfastsvt@cs.com
Old Nov 12, 2001 | 04:34 PM
Tundra's Avatar
Rest In Peace
From: anchorage, alaska, usa, north america, earth, solar system, milky way
11secL,
How did you get by the support bracket that would seem to block a lot of the in coming air?
i though about that, but it looked like it would require a dremel.
