premium stereo amp?
Old Oct 12, 2001 | 11:30 AM
kidd2001's Avatar
Question premium stereo amp?
I just bought 4 kenwood exelon 6x8's, a JL microsub 8.1, and an MTX thunder 4405 to power it all. I will keep the factory HU, and add two line converters so I can hook it all up. My question is, do I need any adapter/converter to bypass the tiny amp that came with my 2001L. Is this premium amp in the dash? If I use one 4 channel converter, will I still have control over balance and fade adjustments? Can I just forget about this factory amp, or should I remove it? Any info would be greatly appreciated!
Old Oct 12, 2001 | 11:55 AM
Don C's Avatar
correct me if I am wrong, but I don't think there is any amp in the Lightning.
Old Oct 12, 2001 | 12:25 PM
kidd2001's Avatar
I wasn't sure, I saw something on one of the forums stating their might be one. If nobody has run into this problem, their probably isn't one.
Old Oct 12, 2001 | 12:44 PM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
No amp. in the Lightning. Only comes in thr Premium system found in Expeditions, etc..
Old Oct 12, 2001 | 01:33 PM
kidd2001's Avatar
thank you sir
Old Oct 12, 2001 | 02:37 PM
TampaSVT's Avatar
You are quite welcome...
Old Oct 12, 2001 | 03:32 PM
kidd2001's Avatar
can anyone help me out with the differences/advantages/disadvantages of using a four channel line converter, instead of two 2 channel lineconverter?
Old Oct 12, 2001 | 03:51 PM
KlutzEnhiemer's Avatar
Hi Kidd, the only advantage you'll get by going with the 4 channel system and stock HU is fader control. I tried just keeping the factory HU and adding an amp and it didnt sound too good. I bought a single disc HU and went through the preamp outputs and got 100% better sound. even with that awesome amp the frequency range is still determined by the head unit.
Old Oct 12, 2001 | 04:26 PM
kidd2001's Avatar
Thanks. The only reason i'm keeping my stock HU is because where I live and work, about once a month someone tries to break in to my truck. I wan't to be as low key as possible. thanks again for the info though.
Old Oct 12, 2001 | 11:34 PM
understandable... I'm just waiting for the fool to TRY to snag mine.
protected @ home by clifford G4 and a small cal handgun with hollows and a badass operator
Old Oct 13, 2001 | 10:20 PM
johnb62's Avatar
I just installed a Kenwood in dash CD with Memphis 5x7 two ways in the front and Kenwood 3 ways in boxes in the rear. Yhe Memphis speakers are awesome. I did all the work myself.
However the factory amp screwed me up. I hat to go to the stereo shop to get it wired right. Sounds great now.
The only problem is a slip of the screw driver while mounting the single DIN unit. That resulted in 4 stitches and a tetanus shot.
Oh well the stereo was worth it!
Old Oct 14, 2001 | 09:37 AM
kidd2001's Avatar
I thought we just went through this and everyone on this thread states there is NO factory amp. What do you mean buy that statement? Are you talking about the 2001 L stereo?
Old Oct 14, 2001 | 11:31 AM
johnb62's Avatar
Sorry for the confusion. I am talking about my 97 F150 supercab. I picked up on the thread because of the factory amp issue. My truck does have the amp.
Johnb
