Found the boost clip, but I'm having a ball trying to release it, HELP
Hey, I found the boost clip, but I am now having a heck of a time removing it. I don't want to break it off. Someone posted that all you have to do is lift it with your index finger and remove it. I guess their hands were smaller than mine, or I might be trying to lift up the wrong end. I sure would appreciate someone breaking this down to me, thanks.............Phatford
Maybe you should think about ordering the Boost Dump By-pass Kit from JDM. I like the fact that you don't have to mess with the plug,and trying to remember if its plugged in or not! Also it took about five minutes to install.
I know the clip is on top, but which side do I pull-up on, the supercharger side, or the driver side of the clip to release. And, how much is that bypass gonna run me. thanks..............Phatford
Stick a flat blade screwdriver under the clip. Barley push it up, not hard, while pushing it off. I leave mine unplugged.
You can press the back, which lifts the front. Kind of like one of those lever thingies.
However, mine was tight and I couldn't get it to work the first time. Screwdriver worked for me. However, I've been known to use the wrong tool for the job more than once. Heck, I take my lugnuts off with pliers.
