Boost cut out question
Old Oct 10, 2001 | 11:45 AM
usahooters's Avatar
Question Boost cut out question
Can someone tell me what exactly makes the boost cut out activate? Is it the RPM's or High Boost or what? I went to the track last night and I forgot to unplug it, I made a great first pass came right back around and launched out tight then it hit me like an anchor. I read awhile back that some other are leaving it unplugged all the time, Is this a good practice or not? I can hear a difference in the air being relieved from under the hood but no other effects. I have made the boost actuator adjustments and its put my boost well into the black above 10# and still running stock pulley's. If its not a good idea to leave it unplugged all the time I'm thinking of mounting a remote switch in the cab for convenience. Thanks for any info
Old Oct 10, 2001 | 12:33 PM
LIGHTNINROD's Avatar
Mine's(along with several others) been disconnected for 8-9,000 miles--daily driver/1/4 miler--with no problems. JDM provides a by-pass kit for those who don't want a 'code' set. No 'surprises' at the track!
Dan
Old Oct 10, 2001 | 12:52 PM
Phatford's Avatar
Where is this thing located, and how do I go about disconnecting mine? Thanks.................Phatford
Old Oct 10, 2001 | 01:18 PM
DHFerguson's Avatar
phatford - read these threads:
https://www.f150online.com/forums/se...der=descending
Old Oct 10, 2001 | 03:06 PM
usahooters's Avatar
Thanks for the info Lightningrod, So is it the Rev Limiter thats cutting it out you think? For now I'm just going to leave mine unhooked also.
