HOLY heavy Batman....
Old Oct 1, 2001 | 04:52 PM
L in Detroit's Avatar
just got done swapping the stock fan for 2 14" ele...
now i can see where the extra horses come from when removing the rotating anchor from the front of the water pump..
havent decided weather to go with a temp switch for the fans or a rmp switch, so the fans are on all the time, from a switched power source and it sounds like i have a turbine motor mounted up there..
but the mod is definitely worth the time and cost, better responce and in the morning my truck had the loud moaning noise, like the cherokees have when their cold, now that is gone and worth it right there..
earlier i posted where to mount the i/c tank res. when removing the shroud, what i did was to cut out the part where the tank is mounted with some extra for support and it stayed in the stock location with plenty of room for the two fans..
i also put two 6.5" on the ic heat exchanger but their not on now, ill just give them power when i think i need it, with all 12V stuff on, radio, defrost, lights, fogs, two fans, the alt was having fun keeping up so, there staying off for now.
jim
