MTX Thunderform sub box
Old Sep 25, 2001 | 09:31 PM
Lowner's Avatar
Any experience with this box? The pic online makes it look like it's made out of plastic. Is it?
I like the way it forms to the cab of ao reg cab pu.
I was thinking about buying an empty box and putting two MBQuartz 10's in it.
Thoughts?
Old Sep 25, 2001 | 09:51 PM
2l8uburn's Avatar
i have the mtx thunderform box loaded with two 10" thunder 6000's. the box fits great and looks great. i would highly recommend getting it loaded with the mtx subs there quality stuff and i got my box loaded for 300 bucks so i think a good deal two.
Old Sep 25, 2001 | 10:00 PM
lightning0513's Avatar
I also have the same box but I have it loaded w/2 JLaudioW3.It sounds real good. And yes it is a hard plastic, pretty steardy.I recommend the box. Another good thing is you don't lose any leg room.
Old Sep 25, 2001 | 10:14 PM
NOSTROMO
Guest
Posts: n/a
I was looking at the same box.....would you guys reccomend the amp that comes with it? I already replaced the stock 5x7's with some three way polks but the stock head unit isn't strong enough when you crank em up now.
I plan to change the head unit and i already have the stock speakers replaced. With this box will it drown out the sound or will it sound perfect without any other changes besides the ones i plan to do?
Old Sep 25, 2001 | 11:40 PM
Dank's Avatar
MTX Thunderform
I just ordered a loaded MTX thunderform yesterday. I already have an amp (320 watt RMS MTX), that I will be using to power it with.
I'll let you know how I like it.
Dan
2001 Red
Old Sep 26, 2001 | 12:02 AM
LOCOSVT's Avatar
Thumbs up
Thumbs up on the box, looks good and is very durable. No carpet to try to match. Mine is also loaded with the 10" 6000s. I just wish they offered it w/12"s. I don't think I'd go with the built-in amp. If you have problems, you'll have to ship the whole friggin' thing back. I'm running mine off a cheap Crunch amp 800x1x4ohm and it cranks. The 10s tend to break up a little early under 45 Hz, but they have good punch, and blend well with door speakers.
Old Sep 26, 2001 | 01:36 AM
Deus's Avatar
To actually answer your question. The enclosure is made ouf ot ABS plastic. I contemplated going with the empty thunderform enclosure, but instead opted for a single Illusion Audio ND12. Its about the only 12" subwoofer out there that fits without a problem since it is only 3" deep. Its not for the bassheads though but is one of the best sounding subwoofers on the market. I had the choice of dozens of companies as I am a retailer in the caraudio market and went with these even though I don't carry them. If you want to see some pics of the ND12 head on over to http://www.onlinecaraudio.net/nd12
Old Sep 26, 2001 | 06:53 AM
Lowner's Avatar
Thanks for the replies.
I think I'll give it a shot. I do like the clean look of the install.
Has any copied it out of other materials?
Old Sep 26, 2001 | 07:23 AM
Madhouse's Avatar
Does it block the rear speakers?
Old Sep 26, 2001 | 10:36 AM
Lowner's Avatar
Another question.? Has anyone tried putting a sub in the rear speaker compartment? Is there enough room?
Old Sep 26, 2001 | 10:53 AM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
The MTX Thunderform with JL Audio W3's it a great combination, IMO.
