just picked L from i.c. fix
Old Sep 19, 2001 | 05:15 PM
hugo blk lytn's Avatar
Red face just picked L from i.c. fix
apparently my L is good to go. I picked it up right a while ago. they topped off the i.c. fluid and it looks like they replace the black rubber hose that exits the i.c.
Are they supposed to replace the container or does that sound right.
they did it in one day. i mentioned o1b81 to them and they said they would order the part and have it ready for me next day and sure enough they did.
i don't trust my ford dealer though so i want your opinion as to what they did on my truck.
hugo
Old Sep 19, 2001 | 06:02 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Arrow
go over your receipt with a fine tooth comb and cross reference the "fix" part numbers as well as the others.
Bob
wilywilky's Avatar
Hi hugo:
Did they also replace the spark plugs and do the cylinder compression test?
I believe those are required by the new "TSB".
Wilk
Old Sep 19, 2001 | 06:09 PM
superfords's Avatar
01b81
01B81 doesn't say anything about a compression test or replacing spark plugs. All you do is replace the intercooler (and upper intake assembly I believe) and then refill the system with antifreeze and then pressure test the system at the resevoir to verify that there are no leaks.
later,
chris
Old Sep 19, 2001 | 07:52 PM
wilywilky's Avatar
I stand corrected.
Wilk
Old Sep 19, 2001 | 07:59 PM
ib fast's Avatar
Smile
Had this done monday and they did change the plugs but they do NOT replace the supercharger. Sounds like the plug change varys from dealer to dealer.
