Need Help With Headlight Bulb Replacement
Old Sep 10, 2001 | 08:31 PM
Litenin75's Avatar
I've searched and I can't find anything that helps. I can get the bulb loose by turning the ring, but I can't get the headlight free from the ring. The ring seems to be held in by sheet metal on the inside of the engine compartment. Does anyone have any tips on removing the bulbs or does anyone know of an easier way to change the bulbs.
Old Sep 10, 2001 | 08:34 PM
NozeBleedSpeed's Avatar
Pull up on the handles above the light in the square openings.I think that releases them
Old Sep 10, 2001 | 08:46 PM
Ok,I just went out and pulled it out to see how.Pull up on the 2 handles above the headlight and move the light till it comes out of the front.Unplug it,pull light out.Twist off the black ring.Wiggle bulb while pulling untill it pops out.VIOLA!
Old Sep 10, 2001 | 08:59 PM
Litenin75's Avatar
Thanks Noze, it worked perfect. Appreciate the quick response.
Old Sep 10, 2001 | 09:09 PM
Glad to help.I can get anything apart.Its the putting back together I have trouble with!
Old Sep 10, 2001 | 09:12 PM
Litenin75's Avatar
Took me about 15 minutes. I had trouble with the second light, but I soon realized that the single screw on the inside moves and you have to put it back in place.
