Transmission work
Old Sep 10, 2001 | 12:14 PM
TimBurntire's Avatar
Transmission work
My 1-2 clutch pack is worn out and needs to be replaced. Can anyone tell me what the most heavy duty replacement available is?
Part# ?
Old Sep 10, 2001 | 12:25 PM
RTKILLA's Avatar
I would call up precision industries and see what they say. I know they can build these tranny's up to handle a chit load of power.
Old Sep 10, 2001 | 12:30 PM
LightningTuner's Avatar
Tim, you can use the deisel setup, it has one extra clutch disc, which will give you 20% more clamping force. I believe that is the only part in the Lightning trans that was not upgraded to the best Ford had on the shelf. I'm sure Gregg can go into more detail.
Old Sep 11, 2001 | 12:04 AM
clonetek's Avatar
here's an email i got back from level 10 about their "heavy duty" upgrade kit for our trannys..
www.levelten.com
Dear Brooks ,
Thanks for the inquiry!Sorry about the delay.This is what is included is PTS KIT chutches,steels,oh kit.This kit fixes the problem Ford is having with the 2nd clutch failer.The factory program shuts off 3 injectors when it shifts into 2nd.The reason for this that the torque capacity is greater than what the transmission can handle.The after market fires all 8 in 2nd this cause the 2nd clutch to fail.We have the fix!The latest MMFF on THE FRIDGE has the latest parts.
PTS KIT FO 113-5000 621.00
PTS HYDROSYSTEM FO 210 -4000 149.00
PTS BILLIT TORQUE CONVERTOR FO 355-5000 800.00
(i'm guessing he messed up and typed 3 instead of 4 injectiors)
Old Sep 11, 2001 | 12:26 AM
Silver_2000's Avatar
http://www.levelten.com/store/ford/i...3_5000_pts.htm
IS IT
"Time 3-4 hours to install Skill 2 Must remove transmission. "
OR
"Time 4-6 hours to install Skill 3. Must remove transmission. "
Install time ??
Doug
Old Sep 11, 2001 | 12:42 AM
clonetek's Avatar
doug, in our case, i think you add the two maximum times together if we try to do it ourselves..
i'll take it somewhere to have it done.. i've no need for a hot transmission fluid shower.
brooks
Old Sep 11, 2001 | 10:49 AM
I need Gregg's number asap, please.
Tim
Old Sep 11, 2001 | 05:42 PM
clonetek's Avatar
i emailed you a while back greg. i need a goal to start saving towards.. if you know what i mean.
guys, it looks like gregs stuff is the way to go!
tim: i've got a week of vacation i can take next month.. want to caravan up there? got a bedrug and a sleeping bag too.. maybe he'll let us stay in his yard? hehe
brooks
Old Sep 12, 2001 | 10:55 AM
Thanks, but I think we got it figured out.
Old Sep 12, 2001 | 11:22 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Brooks,
If head to Cincy, you damn well better make a pit-stop in Indy.
Old Sep 12, 2001 | 03:52 PM
clonetek's Avatar
LOL @ bob
Old Sep 13, 2001 | 08:24 AM
Factory_Tech's Avatar
Been tweaking a little here and there, and sometime between now and Thanksgiving I'll be sending to Sal a new Forward/Direct clutch package made for Lightnings that will be stonger than the Diesel "044" and the current "036" clutch pack for a truly bulletproof package. The new "044" (direct clutch) will have 7 plate stack (40% improvement over stock package) and the "036" (forward clutch) will have a 6 plate element which is a 33% improvement. I'm divided on whether to make it the whole heavy clutch package or just the parts that are different than the stock ones. (input please, it'll be cheaper with just the modified parts). I'll also be removing the "wavy" plate which is there just to soften the shifts up, so this is going to be a really really firm shifting package. I have one at the machine shop now, should have test units in a few trucks in two weeks ( the first one is mine). Sal doensa't have any more info than this, so don't deluge him, and it's a work in progress, but I've decided to solve the weak intermediate clutch problems I hear a lot about lately.
We can rebuild it, we have the technology, we can make it stronger, faster, better. Hope it comes in at less than 6 Million dollars, too.
G
Old Sep 13, 2001 | 08:42 AM
Frankinaustin's Avatar
Suggestion??
Hello, Mr. Factory tech! I've been reading your posts for a while and you prove your credibility with detailed and specific info.
I am thinking about putting an aftermarket centrif. blower (ATI) on my 2000 4x4 F150 w/ 4R100. What should I do to my transmission minimize future financial heartache? Anything? I remember one post you made that seemed to shade software/chip alterations to the transmission as bad. Perhaps should I leave everything the way it is with my trany?
Your advice will be most appreciated.
Frank
Old Sep 13, 2001 | 08:53 AM
The 5.4 4R100 model is the weakest iteration of the tranny, it has 3 gear planets all the way thru, only a 5 plate OD stack, and the weaker direct clutch. All Gas models come with a 4 pale "044". The planets are in the "360"
You'll want to add plates to the O/D stack, get 6 gear Low/reverse and forward clutch planets and get a 4 gear o/d planet. You also may consider a balanced heavy clutch package (mates with a balanced coast clutch).
You also want a shift kit, buy mine or Level 10 or one of several other ones, it's strictly a matter of prefernce which one, they all so about the same thing, but get one. (I think mine is best, but hey, it's mine after all).
You may also consider a boosted pump, a 6 plate coast clutch with ball bearings (the stock one has a plastic thrust washer) and a deep pan with a drain plug.
That's about it for the novice, I could do more, but it gets into serious money after that (maching and fabrication).
Hope this helps,
G
Old Sep 13, 2001 | 10:02 AM
rscoleman's Avatar
If you make them, then sign me up for a kit!
