MM & FF Article
Old Sep 5, 2001 | 08:39 PM
sixpipes's Avatar
Question MM & FF Article
I am looking for the article in MM & FF magazine that covered the 3.0L Duratec swap for the Contour SVT. The issue was from earlier this summer. Help locating a copy would be greatly appreciated.
Old Sep 5, 2001 | 08:56 PM
SVTShadow's Avatar
Go straight to MM&FF website http://www.musclemustangfastfords.com/
Then click on the "Past Issues" link. You can view a briefing on previous issues and order straight from them. Takes about 4-6 weeks I believe.
Old Sep 5, 2001 | 10:26 PM
sixpipes's Avatar
Thanks Shadow - Looks like the May Issue is the one I'm looking for. Unfortunately I can't wait 4-6 weeks for the article so I'll try to locate it at a local shop.
Old Sep 5, 2001 | 10:55 PM
captainoblivious's Avatar
sixpipes - check out the contour forums @ svtperformance.com and contours.org
you might find better info there
Old Sep 6, 2001 | 04:37 PM
morrisc's Avatar
hey sixpipes I have this mag I could make some copies and fax it to you.
