Will JL 90mm MAF mount on airaid box?
I have the JL 90mm MAF and chip on the way and was wondering if the MAF will mount directly on to my airaid box. Was wondering if I will have to do some customizing of my own. I just mounted my own ram air setup into the bottom of this box so I would hate to have to remove it.
Nick
Nick
from what I understand from the folks at AiRaid, the short answer is NO.
You should/may be able to modify an AiRaid box to fit your 90mm MAF, but they told me that their box won't fit an '01L (which as you probably know already is equipped with an 90mm MAF).
hope this helps, good luck.
later,
chris
later,
chris
I don't see why it wouldn't. I mounted a Pro-M 80 with it's attached filter in a airaid box on my 99. It wasn't easy, it just took time to carefully grind out the opening and mounting pad for the maf. If you have a grinder, wirefeed welder and a few beers
anything possible!
anything possible!
Actually, I didn't miss it. Without modyfing it will not. I was trying to imply that I would recommend the stock air box over that Air-Aid anytime. In fact..... for spring and summer I would run a modified stock box, and a conical for fall and winter.
THE GREEK
THE GREEK
