Driverside oil breather question....
Old Aug 30, 2001 | 09:59 PM
JeffsLightning's Avatar
I have done a search and I'm not sure which driverside valve cover breather will fit the stub that is in there now when you pull the boot hose off. Do I get a 62-1020 or 62-1340 K&N? I have also seen where some have used a Mr. Gasket #2049. Which one is the way to go and will complement my passengerside Ford motorsport breather... thanks Jeff
Old Aug 30, 2001 | 10:06 PM
LightningTuner's Avatar
Question
Why do you want to put a breather on the drivers side when you already have one?
Old Aug 30, 2001 | 11:08 PM
Sal since there seems to be allot of crankcase vapors I thought 2 vents would be better than one. Maybe my theory is not correct....don't know. Jeff
Old Aug 30, 2001 | 11:49 PM
Ok, just curious, wanted to make sure you knew that you didn't HAVE to vent the drivers side, because the valve covers are connected by the crankcase
