What are the differnces between '99, '00, and '01s?
Old Aug 27, 2001 | 07:09 AM
topsy's Avatar
I'd like to understand exactly what where the changes made to each model year.
Old Aug 27, 2001 | 07:21 AM
Madhouse's Avatar
Here's my limited knowledge:
1999 - 2000
Color-keyed mirror backs
14mm lugs ('99 had 12mm)
2000 - 2001
Asthetic things - wheels, lights, grills
3.73 gear ('99-'00 had 3.55)
90 mm MAF ('99-'00 had 80mm)
Bilstein shocks
Stickier compound Eagle F1's
I'm sure I left some things off the list....
Old Aug 27, 2001 | 07:38 AM
BigD's Avatar
Lightbulb
1999-2000
Also the overhead console was added to the 2000 and the tailight changed (position of the backup light clear spot). There were no engine changes in 2000!
Cheers,
...Dwight...
Old Aug 27, 2001 | 08:31 AM
BadAzz516's Avatar
Rest In Peace
Talking
1999
Mirrors werent painted to match color of truck.
No over head console with temp. and compass.
White back-up light in tails was in the center of the tail lights.
Spot in dash below shifter where you could put stuff.
Also not sure but i recall the 99's being rated at 340 Hp Stock.
2000
Mirrors painted to match the color of the truck.
Overhead console with temp. and compass.
White back-up light in tails was at the top of the tail lights.
Spot in dash was gone.
Rated at 360 Hp stock.
2001
Mirrors have blinker on the side.
New clear tail lights, clear head lights, clear corners, and clear fog lights.
New Rim design.
New Grill to replace honeycomb from 99 and 00.
New tire compound used along with a new tire im pretty sure.
3:73 gears to replace 3:55's in 99 and 00.
Rated at 380 Hp stock.
Vin
Old Aug 27, 2001 | 08:34 AM
4D THNDR's Avatar
'99 had optional 6 disc, towing, and tonneau.
'00 made everything standard except optional tonneau. Added drivers side "oh sh*t" handle, overhead console, color keyed mirrors, 12mm to 14mm increase in wheel lug size, taillights changed from all red to clear center, added silver as an option.
'01 added 20HP to make it 380HP. Completely new lighting all around including the over bed brake light. Went from a 3:55 to a 3:73 rearend, improved intercooler, enlarged the airsupply from the fenderwell, signal mirrors(I think), "oh sh*t" handle above passenger side, different wheel designs, different lower crank pulley design.
Front end "clunk" standard for all years with optional leaky intercoolers for the '99 and '00 years...so far.
I think that covers most...
Old Aug 27, 2001 | 11:11 AM
OleSprky's Avatar
1999 Lightning:
Non-color keyed mirrors
Opening in dash panel
Auto-Lamp function adjustable with a rotory switch next to the dimmer control for the interior lights
No overhead console
No privacy glass in back window
Back-up light in taillight was in the middle
CD Changer, tonneau cover and trailerhitch were optional
Red, White and Black were the only color choices
2000 Lightning:
Color keyed mirrors
Dash panel opening gone
Auto-Lamp is preset from factory and activated by turning headlight switch to the left
Overhead console added
Privacy glass back window
Backup light in taillight moved to the top
CD Changer and trailer hitch were standard, Tonneau cover is the only option
Red, White, Black and silver color choices
2001 Lightning:
Color Keyed Signal mirriors
Clear Head, Tail, Signal and fog lights
Horizontal upper and lower grills
New design rims
LED third brake light with new spot light cargo lights
Bilstein Shocks
3.73 gears
90mm air meter
Revised intake and intercooler
Tonneau cover as only option
Red, White, Black and Silver color choices
I'm sure that I must have fogotten something.
Old Aug 27, 2001 | 11:34 AM
Drkone's Avatar
Smile Oh and the most important change...
...The sun visors for 99 and 2000, were standard single ones with non lighted mirrors.
The visors for 2001 are lit and they have a second visor that folds down when the main one is to the side...
Heh heh, had to throw that in there....
Old Aug 27, 2001 | 11:38 AM
BfB's Avatar
BfB
Banned For Rules Violations
Originally posted by BadAzz516
1999
No, the '99 and '00s had 360hp stock. There were no power changes until 2001 (380hp).
BfB
Old Aug 27, 2001 | 10:18 PM
Fast Gator's Avatar
BIGGEST difference between my 99 and the 01. The 2001's monthly payment is $22.00 less! Now that progress!!!
Old Aug 28, 2001 | 01:30 AM
SpoonDog_SVT's Avatar
One thing FlashSVT and I found this weekend is that the '01 have an additional 4-prong connector on the tow-hitch electrical connector that my '00 doesn't have.
~rick
Old Aug 28, 2001 | 09:39 AM
Factory_Tech's Avatar
From a strictly Transmission point of veiw, hte 99s have a differnt Solenoid, (in 00 they added another filter, I think), the 2000s and teh second Model (2001.5) are almost identical except the clutch plates in the intermediate clutch are a differnt material, the original 2001s had the mechanical diode on teh direct clutch, but they switched back to a Sprag assembly half way thru the model year and the 2002 is the same as the 2001.5. Also, all three years have different EEC software, so a chip from any given year will not work on any other year to the best of my knowledge, a tuner may tell me that's wrong, but it's what I've been told.
G
Old Aug 28, 2001 | 10:44 AM
insanedaddy's Avatar
What about the drive shaft's on the 01's. Is it aluminum?
Old Aug 28, 2001 | 11:29 AM
Madhouse's Avatar
Good call, insanedaddy, the new trucks have the aluminum driveshaft.
