Grill Replacement Hlep
Old Aug 24, 2001 | 08:58 PM
99WhiteBeast's Avatar
Question Grill Replacement Hlep
99L-
Is the black honeycomb grill a separate piece than the painted fascia that surrounds it and the headlights?
If so how the heck does it come off?
I've removed the black top cover that spans the gap between the grill and the radiator and still can't see where or if they are seperate pieces.
Any help would be appreciated.
Old Aug 24, 2001 | 09:15 PM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
You're only half done.
There is a black plastic skirt that runs along the bottom that will have to be seperated from the shell. They are just press in plugs.
There are two screws on each side behind the corner lights. Take them off and you will see them.
You don't have to remove the head lights.
When all of that is done, look through the grille. There are two clips that hold it on directly in the center. Pull hard!
You should be holding your grille at this point. The center just pops out of it.
Hope that helps.
