need help with lower pulley install!!!
Old Aug 21, 2001 | 06:16 PM
SVTCLAY's Avatar
Question need help with lower pulley install!!!
I installed a lower blower pulley today and it seems to wobble up and down when the truck is at idle. I removed the pulley to check my work and found the pulley not to be a perfect fit on the crank hub?? When the bolts are loose you are able to move the pulley in any direction about a 1/4in. The hub is smaller then the opening in the pulley. Are you supose to center these things by eye??? Anyone else have this problem. I think i may have gotten a incorrect pulley. I would like to go to the track on wed night but i'm afriad the belt might come off at high rpm. thanks for any input..
Old Aug 21, 2001 | 06:18 PM
DB's Avatar
DB
Hmmm they're not supposed to wobble. Whose pulley are you installing?
Old Aug 21, 2001 | 06:19 PM
Madhouse's Avatar
Where did you get it?
Old Aug 21, 2001 | 06:28 PM
LightningTuner's Avatar
If the hole in the pulley center is larger than the raised portion of the balancer, it sounds like you have an 01 pulley and a 99-00 balancer. Did you get the pulley from us?
Old Aug 21, 2001 | 06:38 PM
SVTCLAY's Avatar
I got the pulley from JL. What your saying is correct the raised portion of the hub is a loose fit in the pulley. My truck is a 99, do you think i got a 01 pulley?? Do you think it is safe to drive like this??
Old Aug 21, 2001 | 06:41 PM
superfords's Avatar
not sure exactly about why you have a wobble, maybe it is like some said above about being for the incorrect year application, but my advice would be NOT to drive it like that.
Seems like to me that would cause some serious crankshaft harmonics (vibration problems) that could possibly damage your crank bearings and hurt your motor.
just my .02
later,
chris haynie
Old Aug 21, 2001 | 06:42 PM
Exclamation
You should not have play like that. The pulley is supposed to center on the damper, not by the bolts. You should not drive the truck like this.
Old Aug 21, 2001 | 06:51 PM
SVTCLAY's Avatar
Angry
Haaaa! @#@#@##@ I guess i won't be going to the track tomorrow night. Thanks for the input. Time to email JL and find out what is going on...
Old Aug 21, 2001 | 07:58 PM
JohnnyLightning's Avatar
You Got a 2001 pulley..Our mistake Send it back right away and we'll send the correct pulley out overnight! I'll also reinburst you for your shipping...Sorry! JL
Old Aug 21, 2001 | 08:03 PM
L-MATT's Avatar
that 01 pulley could have been mine......
Old Aug 21, 2001 | 08:05 PM
L-matt: It was! J/K JL
Old Aug 21, 2001 | 08:08 PM
L-MATT's Avatar
in case you didnt have it noted i need an 01 pulley....do you have a flip chip yet?
