? About Superchips....=(>
It could be that you did not clean the computer contacts well enough. I had this problem until I took out the computer and re-cleaned the contacts. I have not had the problem since. You also want to make sure that the chip is actually taped into the computer so that it will not move. Good luck.
Dave
Dave
Did you duct tape in place? If not, then do. If you have, make sure when you pulled the tape tight you didn't pull the chip to one side and the tape is pulling straight down on the chip. If all else fails check your contacts again.
