METCO INC,interchangable pulleys?
hey guys been a long time,since ive been here,i see things have changed around some,looks good.i was just wondering if anybody else,was running metco pulleys?i bought some this past saturday,and had the kit installed at parkway ford,in adairsville ga.the kit contains a stock size pulley,and a smaller pulley,heres the trick,you replace the stock pulley,with a hub assembly,and then with just 4 allen bolts you can change between stock size and performance size in just a matter of minutes.the good puley is worth 2 or 3 pounds of boost,thats what metco claims,ill be going to the track this friday,and ill see if i can see some lower numbers,ill let you know.
SVTRobG,the quality is high,and also a trick setup,i like being able to run the stock size,and dont have to run the small pulley,all the time,i think it was a good mod,ill know for sure this friday.
