Calling Factory Tech
Old Aug 12, 2001 | 05:32 PM
BigD's Avatar
Question Calling Factory Tech
Hello Factory Tech,
Just a question about Transgo Shift kit. I bought a kit which is marked AODE-HD2. Dec 2000 Sol Valve Upgrade. My question is:
Will this kit work in the 99 L, and is it a good kit to install. There is some drilling required, and thought I would ask the expert before I took it to a tranny shop, and had the kit installed.
Thanks for the help
...Dwight...
Old Aug 13, 2001 | 07:03 AM
BigD's Avatar
ttt
Old Aug 13, 2001 | 08:40 AM
Factory_Tech's Avatar
It looks from the part number that the kit you bought is for a 4R70W. What tranny do you have? Any tranny shop can install a shift kit, they're pretty straightforward installs.
G
Old Aug 13, 2001 | 09:57 AM
BigD's Avatar
Hello again,
I have a 99 Lightning...and was told that this kit was for the stock tranny...sounds like I was led astray
Thanks for your help,
...Dwight...
Old Aug 13, 2001 | 10:01 AM
LightningTuner's Avatar
Dwight, it sounds like that kit is for the AODE/4R70W trans, which is not what you have. You would need a kit for the E4OD/4R100 trans. If you can return that kit, I do sell the Factory Tech valve bodies. It is a complete new valve body already built for performance, and it's a bolt in unit, no need to take apart your stock valve body.
