Are 12s possible in 2001 L without a chip?
Old Aug 9, 2001 | 11:36 AM
CEB's Avatar
CEB
What kind of mods, chip excluded, would it take to get into the 12s with a 2001 L?
Old Aug 9, 2001 | 11:47 AM
Ivanhoe_Farms's Avatar
More Boost or Nitrous --- maybe both
Old Aug 9, 2001 | 11:54 AM
RTKILLA's Avatar
ANYTHINGS possible!
I'm going to make my 99 go 7.???, HAAAAAAAAAAAAAAAAAA. got to beat jason brown!
Old Aug 9, 2001 | 11:59 AM
DB's Avatar
DB
The one major problem is going to be that without a chip tuned for the mods that are going to significantly reduce ET's (e.g. nitrous), your A/F ratio is going to be leaned out considerably.
Old Aug 9, 2001 | 12:04 PM
RTKILLA's Avatar
run a wet kit and you can dump more fuel in there.
that way you can adjust the Air/fuel ratio.
make sure you buy an EGT so you can tell what the A/F is though.
Old Aug 9, 2001 | 12:29 PM
HIGH ROLLER's Avatar
Talking
Most definitely possible,i ran a 13.14 at 106.40 with just a PSP pulley and throttle body and no chip in 70 degree air with several other L's watching me!If i had 55-60 degree air i know my L would run high 12's without a chip with no problem!
Matt
Silver 01
12.85
109.40
80 degree air
Old Aug 9, 2001 | 12:50 PM
Spike Engineering's Avatar
It all depends on your speed at the beginning of the 1/4 mile
Tuesday at Thunderheat/hill, I was entering the main straight at 45+ (I wasn't watching the speedo). I don't know what my speed or time was 1320 ft later because I still had about 400+ ft to go before I'd enter the braking zone.
You guys should give it a try sometime!
Spike
BTW
Air temp: 104 degrees
Track temp: 132+ degrees
