Mass Air Flow Sensor ?'s
Old Aug 8, 2001 | 05:58 PM
Houndog's Avatar
Question Mass Air Flow Sensor ?'s
I see a good deal on Pro M 80 maf..What is my stock sensor size.
Also what do I need to do to run the Pro M 80 ?
Thanks In advance.
Old Aug 8, 2001 | 06:27 PM
DB's Avatar
DB
The search function might not be up to speed at the moment, but lots of info like this can be found with it.
Stock MAF on a 99/00 is 80mm, 01 is 90mm. You can upgrade the 99/00 to a 80mm pro-m (better than stock 80mm) or the Ford 90mm MAF, but you need a chip reburn so you don't lean out.
Old Aug 8, 2001 | 08:19 PM
dark_horse's Avatar
Banned
Re: Mass Air Flow Sensor ?'s
Thanks In advance.
I have a 80mm pro-m for sell if you're interested.
Old Aug 8, 2001 | 08:23 PM
red2k#1554's Avatar
I have a 90 mm 01 sensor available if you are interested.
hockeybuff@earthlink.net
