CALLING hdmlnium
Old Jul 31, 2001 | 07:47 PM
LeenSVT's Avatar
Red face CALLING hdmlnium
Where did you get your drive shaft loop, and how much? I remember seeing it on your ride some time ago and thought it was sweet, also does it bolt on or does it require fab.
Thanks a bunch
P.S. those rims are awesome, Pimp Ride
Old Jul 31, 2001 | 08:05 PM
Don C's Avatar
He has the Metco drive shaft loopwww.metco-inc.com
It bolts under the cab with 4 bolts. You remove the 4 #12 star bolts on the rear of the driveshaft, slide the loop around the driveshaft. Then pull the passenger seat foward, pull the rear carpet up, drill 4 holes. Seal them with silicone, and bolt it in. Then bolt the driveshaft back.
It is not a hard job takes about a hour.
Old Jul 31, 2001 | 09:38 PM
LeenSVT's Avatar
Thanks, do you have any pics of the loop installed
