calling fastrnu
Old Jul 23, 2001 | 08:28 PM
RDY2RAC's Avatar
Talking calling fastrnu
did you get that cooler installed yet? are you going to byron this weekend? and do you think you'll run in the truck class or brackets?
Old Jul 23, 2001 | 09:16 PM
FASTRNU's Avatar
I won't have the cooler until Wednesday. I am still waiting on ratchet straps(hopefully tomorrow) and load equalizing hitch(should be tomorrow). What all do I need to move the battery? If I go I will probably run in the same class as you and the rest of the guys.
Old Jul 24, 2001 | 07:03 AM
RDY2RAC's Avatar
battery box
you''ll need a box(i bought one at autozone for around 10-15 bucks , a battery cutoff switch(30 at ramchargers) and lots of wire, positive side you need enough to goto pos. cable i used a terminal and removed the bolt from existing batt. term. and put it inbetween and rebolted and just taped it up reel good incase i decide to go back to stock i didn't cut anything. and the ground i used about 12 ft. and ran from neg. right to switch and then to the bumper bolt to ground it. hope this helps atleast give you an idea as to what your up against
