Oil in intake hose, why?
Old Jul 21, 2001 | 10:40 AM
DadsBlownToy's Avatar
I haven't been to this site in a few month's, but now I am back with a question that I need an answer to.
I was installing a cone filter on my MAF when I noticed that the intake tube was filled with oil.
What causes this? Is it bad or not to worry?
My truck only has 1600 miles. I have only seriousy taken it WOT only once. Am I breaking it in too easy?
Anything you could tell me about this would help.
Old Jul 21, 2001 | 11:42 AM
LIGHTNINROD's Avatar
DAS(do a search)
I'm new too, but it seems to be caused by oil being sucked into the intake under deacceleration. A lot of guys have noticed this.
A 'possible cure' is installing an oil breather filter in place of the oil cap. But, if you do this, you will need a chip to compensate for 'extra air--lean condition. See LightningForce or JDM.
Btw, if you ask "am I breaking it in too easy", you probably are. I went to wot every day or so from 200 miles on up. But, it's your L; do as you see fit.
Good luck,
Dan
Old Jul 22, 2001 | 03:07 PM
gobarney's Avatar
same oil issue on my 00
Old Jul 22, 2001 | 03:25 PM
2_FAST4U's Avatar
Lightninrod is exactly right, oil gets sucked up the intake on deacceleration and gets on the filter boot. A cure for this is the oil breather cap, and YES you do need to have a chip so you don't get soft codes on the PCM. I have had my cap for about a month now and I just checked it the other day and no oil to be found!!!
Old Jul 22, 2001 | 06:57 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
A few of us opted to remove the "straw" leading from the driver's side valve cover to the intake boot.
Not sure if this requires changing your chip. I think not but mentioned it anyway.
Total cost: $20 All parts available at Auto Zone.
**note** no cleaning of the throttle body was preformed prior to photo shoot.
more pics in my gallery linked in my sig.
Old Jul 23, 2001 | 12:51 AM
Bad as L's Avatar
I suspect the oil is being pulled into that rubber boot on acceleration, since on decel there is no way for vacuum to be there with the throttle blades closed. Also I think the oil is being helped up that tube by crankcase pressure build up(Blowby) while at WOT
Anyway some guys are claiming that running only 5 to 5 1/2 quarts of oil in the crankcase helps with oil control alot. I have always run 5 1/2 in mine (but for different reasons)
and have never had much oil up there.
Dale
