About that engine noise
Old Jul 21, 2001 | 09:29 AM
Lowner's Avatar
My 01 has less that 1000 miles on it. I have always heard a noise at start up but I attributed it to S/C which I wasn't familiar with.
Now I am beginning to question the noise. It doesn't sound like the dreaded piston slap.
It sounds more like a slipping belt or valve clatter.
Now I read about engine flutter.
Seems to just be there at start up. Is this normal?
Old Jul 21, 2001 | 09:47 AM
twiztid's Avatar
Let it run and check it again.
You could have same thing I have. It not piston slap, its more like the pulleys clicking or the trans. I haven't figured it out yet, but it comes and goes. It also went away when i had the S/C Belt off.
Old Jul 21, 2001 | 10:19 AM
Skank Dog's Avatar
I hear a sucking noise at first start up when you mash the brake and put it in gear. Didnt hear this before the K&N filter though. Anyone ever hear this noise?
The only clicking noise I hear is injector pulse.
Old Jul 21, 2001 | 10:32 AM
Frank S's Avatar
Mine just started making that same noise at 700 miles. Has 760 now. Will pay close attention to it to see if it gets louder ot not. I believe it is a pulley since i had the idler pulley replaced at 300 miles. Definately hope its not an internal engine problem
Old Jul 21, 2001 | 11:48 AM
LIGHTNINROD's Avatar
May be valve clatter due to the oil draining back/down overnight? After all, it's 5w20. I've noticed 'something'--too. Haven't worried about it---yet.
Old Jul 21, 2001 | 01:01 PM
ally69's Avatar
The supercharger noise you hear in the s/c snout is from the front snout bearings going out roots style blowers are infamous about that in fact i have read that roots style blowers only draw back is needing snouts and bearings replaced more often then other styles of blowers.
