325/50R20 Tires
Old Jul 16, 2001 | 01:59 PM
D_Coburn's Avatar
325/50R20 Tires
Does anyone know whether or not 325/50R20 tires will fit on the REAR of the L after it has been lowered 2"? I am considering swapping my 295/45R20's and I want to make sure that there is enough width & height for the new tires.
Thanks,
Dave
Old Jul 16, 2001 | 03:10 PM
Silver-Bolt's Avatar
That's a whole lot of tire to put on a rim that width. Do not know for sure if it will fit, but that wide of tire should be mounted on a 11"-12" wide rim. Sounds like a very tall tire setup.
Old Jul 16, 2001 | 03:39 PM
D_Coburn's Avatar
Silver-Bolt-
According to Toyo's website, 325/50R20 tires are approved for 10" wide rims - which is what I have. I am just not sure if they will fit on a lowered L without hitting wheel wells....??????
Dave
Old Jul 16, 2001 | 09:03 PM
D_Coburn's Avatar
ttt
Anyone.......Anyone.......
Old Jul 16, 2001 | 09:20 PM
LOCOSVT's Avatar
check this out to determine the actual numbers involved:
http://www.miata.net/garage/tirecalc.html
According to this, the new tire will fill the wheelwells by 2.17" more than the stock F1. It will also be 1.18' wider, and you'll be back to approximately the stock ride height, but with fuller wheelwells.
