Help! Fuse/relay problem
Old Aug 17, 2011 | 09:20 PM
blakdoutL's Avatar
Long story short, I went through all of the fuses in the L, inside and out. Now when I start the truck the radio dosent work and the windows wont roll down, and the reverse lights won`t work. When I turn the key back for accessories, everything works fine. All of the fuses seem to be in the right place according to the manual........Please Help
Old Aug 17, 2011 | 10:46 PM
Veteran: Army
i must ask, WHY did you mess with all the fuses???
Old Aug 18, 2011 | 09:00 PM
blakdoutL's Avatar
Because my passenger side headlight went out, and the problem was not the bulb. So I went through all of the fuses to find the one that was the culprit. None of them were blown, so I pressed all of them down including the relays, and all of a sudden the light worked perfect, just as it should. As soon as I started the truck, the windows, radio, and reverse lights didnt work.
