chip & tire diameter question....
Old Jul 12, 2001 | 08:10 AM
JeffsLightning's Avatar
Question
Originally posted by DreaminAboutL
Why with Gears but not with Tires... aren't shorter tires exactly the same as putting in gears??
That is my point exactly. With the 26" short tires the pcm thinks that the rearend ratio has been changed. I have an 01 and I don't want to make a mistake and put shorter tires on just to lose performance. I'll just stick with the stock F1's until I can get a 28" tire. So the question is still out there... It would be a biotch if you put shorter stickies on and go slower because the pcm sees something not right...
