Keeping the rear wheelwells clean...
Old Jul 9, 2001 | 08:57 PM
LIGHTNINROD's Avatar
After 10 dry burnouts fri. nite, my wheelwells were covered with tire rubber particles. A friend mentioned he had heard of spraying the wheelwells with something that would keep the rubber bits from sticking. He couldn't remember what it was--I thought of 'Pam'(don't know if that's the right name). I'm talking about the non-stick cooking spray.
Any ideas>
Dan
Old Jul 9, 2001 | 09:03 PM
Don C's Avatar
I just use some quick detailer, mothers, mcguiers, eagleone they all seem to work.
Before I make my runs at the track I just spray the stuff in the wheel wells, and the rear ground effects. I doesn't keep it all off, but about 90%. After it is a lot easier to clean up. 10-15 minutes versus one to two hours.
Old Jul 10, 2001 | 11:50 AM
RTKILLA's Avatar
Its called burnout gaurd.
Old Jul 10, 2001 | 12:49 PM
z96Cobra's Avatar
I don't know if the "Pam" would work, but don't get mixed up and buy "Easy Off"... we use that at work on pumps and electric motors... to REMOVE PAINT! lol
Later,
Roger
Old Jul 10, 2001 | 12:55 PM
BOSTONL's Avatar
Exclamation
Lightninrod:
Not sure how this will work for cleaning up burnout debris, but after 17k miles of all season daily driving, my wheelwells look almost showroom. First, I spray the wells with Simple green, then hose off thoroughly (high pressure car wash works best but garden hose will do in a pinch). After they're dry, I spray them down with a good coating of foaming tire cleaner (this also works well on the undercoating on the frame). Once dry, wheelwells look super. If you want to get alittle ****, use a soft bristle scrub brush with the simple green. I also clean the painted sections of the wheelwells (fender lips and ground effects edges) with a gasoline soaked rag. Works almost instantly to remove road tar. Sorry for the long post!
Old Jul 10, 2001 | 01:05 PM
THANKS
guys--3 senior members and one regular--appreciate it.
Old Jul 10, 2001 | 03:29 PM
Chainsaw13's Avatar
From: Cuttin' Heads with Jack Butler at the CrossRoads!
This might work as well.
I heard about this trick for the outside body panel right behind the wheel, was to apply a very light coating of vaseline. When done at the track, just wipe all the gook right off. Might work for the wheelwells also. A high pressure hose would probably be easier for cleanup.
Bob
