1999 L wheel stud breakage...
Old Jul 7, 2001 | 09:29 PM
LIGHTNINROD's Avatar
Talking to a 01L owner at the track last night--he said he was towing a boat/trailer recently and thought he had a blowout. When he checked, he found 3 rear wheel studs broken. Btw, Tallahassee Ford would not repair his L under warranty. They claimed it was because of something he had done?
Was having it repaired at Riverside Ford(Macon, Ga.) and decided he'd trade it in on a new black 01L.
Old Jul 7, 2001 | 10:28 PM
PFA's Avatar
PFA
I had broke 2 studs on the rear of my '99 when changing wheels. I was using a 4-way and just tightend them up. They both snapped. Unfortunitely, I learned the hard way to replace them, but I didn't pull the axles to do it. It was a pain in the A$$!
Old Jul 8, 2001 | 08:57 AM
I forgot this when i posted my original post.
One of the L tuners had a front wheel stud break off while on a trip recently.
Just a heads-up for the smaller diameter wheel stud Ls.
Dan
Old Jul 8, 2001 | 09:50 AM
99 SVT Bolt's Avatar
Were those nuts torqued down to the correct 100 ft/lbs ?
Old Jul 8, 2001 | 11:21 AM
Fast Gator's Avatar
I like the style of the 99 owner with the broken wheel studs. why fix it when you can just trade it in. Iam TRYING to figure out why I traded my 99 in now. Can't think of it BUT I got a good reason to trade the 01 for an 03
Old Jul 8, 2001 | 01:13 PM
noelvm's Avatar
The biggest killer to lug nut studs is the impact wrench at some cheap tire changer that is set to 120+ psi. They will stretch the studs and they will break later. I have broken some off with a four way in my youth. Now I just tighten up with the four way and hit em with the torque wrench.
noelvm
Old Jul 8, 2001 | 03:40 PM
xjmd44's Avatar
wheel nut torque?
What should the wheel nut torque be on the 2000 and 2001 Lightnings? I've been torqueing them to 75 ft pounds....I hope this is enough !
Old Jul 8, 2001 | 05:19 PM
awhittle's Avatar
xjmd44
For 2000 and 2001 truck, wheel lug torque 150 lb/ft (14mm lugs). For 99's it's 100 lb/ft (12mm lugs).
AW
Old Jul 8, 2001 | 07:46 PM
xjmd44's Avatar
Wow! Live and learn!!
Thank you Awhittle!
I'll re-torque the fastners on the truck ASAP!
