400rwhp??
Old Dec 8, 2009 | 03:21 PM
crashogden's Avatar
400rwhp??
Im about to purchase a lighting with 43000 miles and i was wondering what all does it take to get a lightning to or over 400rwhp.
I was thinking 4# lower, longtubes, CAI, larger single blade thorttle body, aftermarket plenum, sct big mass air meter, Boost A Pump and a boost bypass kit. And a costume tune.
What do yall think??
Old Dec 8, 2009 | 04:38 PM
Veteran: Army
ported eaton, ported or high flow upper plenium, 6# lower, valve body, long tubes, custom tune and a better heat exchanger should have you close
forget the boost bypass the tune will take care of that
don't forget the plugs and a MAF or MAFia
Old Dec 15, 2009 | 03:11 PM
thepawn's Avatar
If you take your list minus the boost bypass and Tarajerame's longtubes suggestion, it is all you need to get just over 400rwhp on a 2001+ lightning. I get about 400 even with that on my 2000 and I've got the smaller intakes.
I'm running:
Mild JDM tune
4# pulley
SB throttle body
custom plenum
CAI
JBM longtubes+exhaust
90mm MAF (stock on 2001+)
and I'm 392rwhp on a hot day.
Old Dec 15, 2009 | 09:37 PM
hiroc's Avatar
Agreed. I'm almost at 390 on a hot day and stock blower. Dyno tune is a huge help with a good tuner.
Old Dec 16, 2009 | 11:26 PM
thepawn's Avatar
Yeah, the difference between the two runs there in my chart are merely the stock ECU and JDM's tune. That's a pump gas mild tune.
Old Dec 21, 2009 | 12:20 AM
Blown347Hatch's Avatar
16 degrees timing, A/F ratio in the low 11's, and the below mods in the sig has gotten me 437RWHP & 447RWHP on different days on different dynos in cooler (for Miami) weather.
Old Dec 21, 2009 | 07:54 PM
crashogden's Avatar
Well got it dynoed today at made 415hp 499lbs. 55 degress outside today.
lfp longtubes, lfp plenum and throttle body, 5lb lower, jlp cai, sct big mass air. boost a pump, jlp power cooler and Double pass heat exchanger.
Porting and Heads/cams will come soon!!
Old Dec 21, 2009 | 10:19 PM
I believe a good port on the Eaton will get you another 20 RWHP or possibly a little more. Also consider the 6 pound lower.
Old Dec 21, 2009 | 10:52 PM
crashogden's Avatar
sweet. i think im gonna wait on the performance parts for a while and get a 3200 stall.
Old Jan 11, 2010 | 08:51 PM
tripleblk97's Avatar
Good move on the stall.
Old Jan 11, 2010 | 09:29 PM
06yz250f's Avatar
And a costume tune.
personally id suggest a custom tune over a costume tune.
Old Mar 7, 2010 | 08:57 PM
Jughead14's Avatar
how expensive is it to port and polish a supercharger and plenum?? or is it just worth it to buy a jlp plenum... i have roughly 10 G to install my L motor into my f150 and somewhat fix it up and i wanna get the most out of it with what i got.
Old Mar 8, 2010 | 12:22 AM
Port & Polish is good bang for the buck on the blower (only) through Steigemeier (SP). On the Plenum, whether you port a factory one or buy aftermarket has almost no gain, just as headers on an otherwise stock truck. If that $10k is for mods, I would look into a Kenne Bell blower.
Old Mar 9, 2010 | 04:28 PM
Jughead14's Avatar
i already know about the kb blowers and i've seen the damage they do i will get one eventually but the 10k is for the motor swap and minor performance upgrades but the rest of the money is going to a new paintjob and complete body overhaul
also, i asked how much the superhcarger porting would cost through steigemeir
Old Oct 5, 2010 | 06:42 AM
01lightningwafb's Avatar
Jughead- it should run about $200-250 for a plenum port. I know you can buy a new one already ported for prolly the same amount of $$. Steigemeir is about 3hrs from me. I have talked to a couple of guys from my area (Warrensburg, Mo.) and they said Steig is the way to go.
