Belt shredded! Help?
Old Sep 17, 2009 | 04:09 PM
20Screw01's Avatar
So my lightning motor finally tore the serpentine belt and wrapped it around the crank pulley. I'm sure it will be fun getting that out but my question is what do I need to do to put a new one on? Do I need to remove anything or is it the same way as putting a belt on a N/A motor?
Any tips would be great!
Thanks guys!
Dave...
Old Sep 20, 2009 | 02:29 AM
20Screw01's Avatar
Anyone?
Old Sep 20, 2009 | 01:49 PM
JollyGiant's Avatar
Which belt?
Old Sep 20, 2009 | 03:04 PM
20Screw01's Avatar
Serpentine accesory belt...
Old Sep 21, 2009 | 11:38 PM
20Screw01's Avatar
Anyone?
Old Sep 22, 2009 | 12:14 AM
I think you have to take off the S/C belt to get the serpentine belt on
Old Sep 23, 2009 | 12:58 PM
oldfrmtrk's Avatar
To replace the accessory serpentine belt you first have to remove the SC belt using a ½ breaker bar or a ratchet. “I usually remove or aside the inner cooler SC reservoir to get better access to the belts tensioner”
Then if you have the stock bottom pulley, you have to either loosen the cage, or remove it all together. (A Pain in the But) One main reason to go with a cage less bottom pulley to be able to easily replace this belt..
Then using the ½ bar remove and replace the belt…
Old Sep 28, 2009 | 05:17 PM
20Screw01's Avatar
Got it thanks!
Old Sep 29, 2009 | 12:58 PM
Houndog's Avatar
I'd be more concerned as to what "chewed" the belt up to begin with.. I'd guess one of the pulleys it drives is out of line with the rest, causing the belt to wear on one side, then shred..
Old Sep 29, 2009 | 04:59 PM
oldfrmtrk's Avatar
YEP!!!!!
Old Sep 29, 2009 | 05:02 PM
20Screw01's Avatar
It was a very old original belt and was cracking so no surprise...
Old Oct 7, 2009 | 06:08 AM
Veteran: Army
what else did you cheap out on, during this swap???? I saw your "tune" thread
Old Oct 7, 2009 | 01:17 PM
20Screw01's Avatar
Didnt "cheap out" on anything just didnt see the belt until it was in the truck. New belt is doing great (gatorback acc and blower belt). Not cheap as you stated....
Old Oct 17, 2009 | 02:05 AM
svt4065's Avatar
Check your alternator pulley - caused mine to do the same thing..
